| Message |
and an extension. Check pad contact areas on calipers, if they are grooved in it will cause noise, There should be tiny little metal shims under the pads between the calipers contact and pad contact areas. Also check front rotors for warpage. Check fuel pressure, TPS settings,Temp sensor, O2 sensors, Injectors.
